Author Topic: ATO vs. ATC blade fuses: what's the diff?  (Read 12493 times)
« on: September 30, 2017, 01:37:05 PM »
OK, the O & C stand for Open and Closed, and you can see openings in the O-type.  They're physically the same size, they fit in the same fuse blocks.  To that degree they're interchangeable.
But what's the difference in their function and purpose?  Is one better than the other in certain applications?
Odd question, I know.  I've been using whatever happens to be on a store shelf without worrying about it and nothing bad's happened, but it would be good to know if there are any pitfalls here.
Online FreeLancer
Re: ATO vs. ATC blade fuses: what's the diff?
« Reply #1 on: September 30, 2017, 01:39:08 PM »
That’s a good question.
« Reply #2 on: September 30, 2017, 02:41:22 PM »
  In my power distribution box I use the ones with the pretty led's that light up when they blow.   ::)
« Reply #3 on: September 30, 2017, 03:34:01 PM »
  The ATO and ATC are the same...except the ATO is open at the top of the blades so it can be tested while in circuit (little slots leave access to the top of each blade )
If there is an advantage ,it is in possible wet conditions causing corrosion or degrading of the fuse element.
EDIT...here is the official word:
The regular-sized ATC fuse is more common than the ATO. The ATC has a fuse element that is closed (hence the “C” in the code) inside the plastic housing, sealing it from the environment to prevent corrosion from developing. The ATO fuse is open on the bottom, exposing the fuse element between the blades.
« Last Edit: September 30, 2017, 03:42:22 PM by Carl »
« Reply #4 on: September 30, 2017, 06:22:58 PM »
So that's it.  ATO pro: open for test probes.  ATC pro: sealed against corrosion.  And otherwise completely interchangeable.
Thanks Carl!
« Reply #5 on: September 30, 2017, 06:25:54 PM »
Thanks Carl!
My dad pulled me aside and told me that ,and some gross stuff about girls when I was 12 years old  ;D
Online FreeLancer
« Reply #6 on: September 30, 2017, 06:27:51 PM »
Makes sense.
« Reply #7 on: September 30, 2017, 06:47:52 PM »
Oh man, that's heavy...
« Reply #8 on: September 30, 2017, 07:00:09 PM »
 I was just a kid and cooties were the worst thing that could happen.
« Reply #9 on: January 07, 2020, 11:42:20 AM »
I have just been informed by Google that this thread is the best-performing page on the entire Survival Podcast website.  Nearly 200 people found this page in the past month by searching Google for "ato vs atc fuse", "atc vs ato fuse", "ato fuse", etc.
 :jaw-drop:
TSP Forum is also popular with people who want to know "how to get pickle smell out of bucket".
