Author Topic: new black Berkey filters running fast  (Read 3115 times)
Offline GodsProvision
    • GodsProvision.hubpages.com
« on: January 15, 2019, 08:31:02 PM »
Brand new black Berkey filters which I primed before installing by using the off grid primer kit. Water runs through very quickly and I am not sure why. Is the plastic separated from the filter? If so, I need to return them.
Re: new black Berkey filters running fast
« Reply #1 on: January 16, 2019, 08:42:09 AM »
Just FYI, 'theberkeyguy' hasn't logged on to this forum since Sept 2017, so he's unlikely to see your question here.
« Reply #2 on: January 16, 2019, 06:07:04 PM »
Give your filter the red food dye test -- a half-dozen drops in the upper container and if the water's coming out significantly less red, you're good to go.  Otherwise, it could be a lot of things.  I'd check that the rubber gaskets are sealing first.  A little (and I mean just a little) film of cooking oil can let things slide and seal down tight.
Offline Applejack
« Reply #3 on: February 15, 2019, 08:40:47 AM »
You can go to the Berkey store website and ask or go to the Berkey Guy website. I did have a set of filters that the ends came loose. I called them and they replaced them for free. It sounds like you might be having the same problem. They did have a series of filters that had a problem and they have been replacing them for people.
